can someone help
trying to make a gear with only I/4 of the circle has teeth that's driven by a complete gear , once it has turn 1/4 and runs out of teeth the 1/4 gear needs to stops . letting the drive gear to continue rotating driving others gears. tried using slots but same problem as soon as the drive handle moves out of the slot it should stop but continues to rotate .
how can I make it stop.
