cutlist for woodworkers
peter_jansen
Member Posts: 10 ✭
Hi,
Been using CAD software for years now. Used Fusion 360, SolidWorks, LibreCAD and FreeCAD.
Very happy to use OnShape now, it works like it should and is very intuitive.
One thing I do miss, and that most other programs have, is a cutlist for woodworkers.
I hoped that OpenBom might be useful, but the free version is useless and so stripped of functionality that I wonder why the bother. There is some cutlist functionalty in the Frames department, but not for 'own' made parts. There used to be a sort of working cutlist in the Beam featurescript.
So my question is: what can I do to get a proper cutlist from the items in an assembly that I designed?
Thanks @john_mcclary for the mention.
The Frames feature is now in the default Onshape tool bar. It comes with the Cutlist feature which is for Frames.
Alternatively you can use the Measure cut list custom feature:
https://forum.onshape.com/discussion/16430/cut-list-new-custom-feature#latest
Note that either of these solutions will require you to either stay in the part studio or bring your parts back into the part studio to create the cut list. Onshape currently doesn't offer "AssemblyScript", so we have to use the part studio for easy production custom tools. You could go the hard way and make an app that does work in the assembly, but there is a reason this is the hard way. CADSharp specializes in custom features and apps, feel free to reach out to us if you need any custom solutions.
RENDERCAD
I would probably also recommend the frames feature. For 'own' made parts, you can create a new sketch to be used as your frame profile. Then the cultist functionality will provide you the frame types, frame lengths and angles if there are any miters.
For sheets, you could use the Sheetmetal function which would then automatically provide you length and with of each sheet.
chadstoltzfus@premiercb.com
Maybe 'autolayout' could be used a base for proper cutlist functionality?
You saidpeter_jansen said: I may be misunderstanding your question, but thought I would take a moment to clarify how Onshape and custom features work. Onshape's primary CAD toolset is written and maintained by Onshape staff, and all of those tools are always available in the part studio to all users (free, pro, ent, edu, etc).
"Search tools" is your friend. We have so many tools now!
There is another way to add functionality to Onshape: Custom features, such as the excellent work by @MichaelPascoe and many others on the forums, including the Measure Cut List under discussion. These aren't _hidden_ so much as _tricky to find_. These aren't written by Onshape staff and as such aren't added to the default toolset for all users, but many of them are extremely high quality and reliable. In my view the community and custom featurescripts are an enormous, largely untapped, source of power and possibility for the onshape platform.
In addition (the reason for this post, really): Community created custom features are safe and secure to use in your work. Even if the author chooses to update it, your version doesn't automatically update - it's your choice if/when to update. As far as privacy and safety are concerned: Custom features can't share/take any of your private data (that just isn't possible in FS, by design). And if you are worried about losing access -- don't be. Even if authors delete the FeatureScript, it won't disappear from your part studio.
