Using curves to add to a part
daniel_crookston
Member Posts: 18 ✭
Hi,
I've got this part (wire bender) that I'd like to beef up a bit. I've got some mirrored bridging curves, and I'd like to fill in the space between those curves and the tube that projects out the side. I've tried adding surfaces, extruding, etc. and can't get it to work. Can anyone help me out?
https://cad.onshape.com/documents/902349103e20abb782112e2f/w/1c74d1840bad12d33f4b9582/e/53f7142e60297f692aee75d2?renderMode=0&uiState=664b59d753f2250ee9462c14
Thank you!
Thank you!
