2024 Onshape feature wishlist
bryan_lagrange
Member, User Group Leader Posts: 991 ✭✭✭✭✭
in General
With the last Onshape update of the year in the books what is on your wish list for 2024?
Here is my list:
- Sheetmetal loft
- Onshape CAM
- Improvement/update to LiDAR scan
- Sheetmetal formed features (louvers)
- Sheetmetal loft
- Onshape CAM
7
I had a quick crack at it here: https://cad.onshape.com/documents/7110a3509e50f046a1d840fb/w/98ed330e5897a77ab1a158c0/e/45a47a40162d6c29536f54c0
It's also a really good test case for exploring some of our new measurements and diagnostics tools (face-tangent angle in particular), and also the use of these measurement tools when viewing a cross section.
Image here is with the connection angle at 10deg. The helper surface I used is hidden, but you can dig it out of my public doc. The connection on the left side is tangent
-Large assembly performance
-Parametric Sketches in Drawings
-Better Interface for Released items (Parts, Assemblies, Drawings)
-More Enterprise Customization
-Advanced Workflow customization
CAD Engineering Manager
RENDERCAD
Sheet metal loft - not just for simple planar sketches
Rip cut on sheet metal between two 3D points or 3D sketch path.
Close up the relief on the corners.
This, a thousand times this.
