How to strip the units from a length?
Hi All,
Is there a way to strip a length of it's units so the decimal number can be used in a "ceil(#/#)" equation?
I am trying to use configs to create an expanded metal/grating generation part studio and have it working well except for getting the desired sheet size to auto size. I am using measure distance FS to get the lengths and widths for the distance of the pattern and am trying to use that measure distance number in the ceil function to drive the instance count. In this case, ceil(#Desired_Length/#Length) or ceil(#Desired_Width/#Width).
Here's the document:
https://cad.onshape.com/documents/07f282dcddf2935fa6750b71/w/2c0dd72f79a3f141eac8e0ae/e/de6fa0c8db0a64009288fb77
Thanks in advance!
Jackson
Thanks in advance!
Jackson
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@jackson_king
You don't need to strip the units at all! A length divided by another length is just a number, so the expression you've proposed is perfectly fine. It looks like you haven't tried it out yet, give it a shot in your document and it should work. (I tried it myself and set one of the pattern instance counts to 'ceil(#Length/#Width)' and it worked as expected):
https://cad.onshape.com/documents/81e1def03ed3ef2f11e46393/w/cb6c92ffab42a4ee16d61ecc/e/cdd309359c16357ecef84025
Jake Rosenfeld - Modeling Team6 -
ilya_baran Onshape Employees, Developers, HDM Posts: 1,234
A better way of doing this is dividing by the unit. If you want the number of inches in #length, use #length / in
Getting the value like @konstantin_shiriazdanov proposed will always give you the length in whatever internal units we're using, which may not be what you want.
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
Jackson
Jackson
It might be easier to answer if we had additional detail about what your user inputs are and what you are trying to do with them
As a learning exercise, I'm trying to plot points to a sine wave like this:
Amplitude, frequency, and x are all valueWithUnits (lengths), and I think that's what I want, but cos() wants an angle, not the unit mashup I have. Should I change all of them to just values? if so, how do I get the right units without the user having to think about it?
Issues with units usually indicate an issue with the equation itself; if you were solving this equation on paper for a given x value, you would expect all the units to cancel appropriately to give you the right answer. So to tackle it in parts:
(e^(-decay/100*x)): this is a scale factor, and should be unitless. Since `x` is a distance, I would expect `decay` to be in distance units, describing how far along the x-axis you want this scale factor to be (e^(-1/100))
cos(x*frequency*degree): As this is right now, I would expect "frequency" to be in inverse distance units (i.e. "1 / distance"), and that (frequency * degree) forms a statement of "for every (1 / frequency), the cos wave changes by one degree". I do not think this is the intention, it seems that you are having the user supply "frequency" meaning "how frequently does the cos wave pass through a full cycle". In which case the correct equation would be: cos(x*(360*degree/frequency)); and you will see here that that the units just fall out correctly, without having to strip anything of its units.
Simplest fix is something like #BaseHeight / (1.5mm).
Like @Jake_Rosenfeld said; "Issues with units usually indicate an issue with the equation itself".
This is very true so probably you'd want to avoid having to use this. But just to satisfy my curiosity i had to think it through.
Because in isLength parameters, users are free to input e.g. this: "(100 millimeter * 1 inch )/ (0.1 meter)".
So what would the unit be?
If you'd ever want to use such a function, I think an isReal parameter with a Unit Enum would be the only way to go.
Users are then still free to use expression to come to the number value. (but it has to be unitless)
Inside the feature, a multiplication of the unit with the parameter would create the valueWithUnits.
The result of your expression is a length, which can be shown in any length units. Onshape will use the length units specified in your workspace to show the value. I think the thing that people seem to find a little hard to digest is that "1 in" and ".0254 m" evaluate to the exact same length value -- it doesn't matter what units were specified in the expression; what matters is the represented length.
