Trying to Make a 2D Shape to Then Extrude
tom_morttom_mort Member Posts: 19 ✭✭
I'm trying to make a clamping bracket that clamps around a round shaft.  I have the shape I want in a 2D drawing consisting of a couple circles a couple of rectangles drawn with lines a small slice out of the circle and an area extending outward for a bracket.
My thinking was I could just join or merge or delete un-needed lines, etc to make a 2D shape that I could just extrude.
Here is a picture of what I'm trying to make and a screenshot of my drawing:
I found similar thread on using the trim tool or just to ignore any extraneous lines and just extrude the faces you want. I can extrude the ring just fine, but not the rectangular and other areas made with lines.
I'm new to Onshape and have used, but not very much and it was some time ago.  It seems like making a 2D shape first and extruding it all at once would be simpler, but maybe I need to make some 3D rectangles and circles and then merge them somehow.
I'm sort of going in circles.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 604 ✭✭✭
    Tom, any of the greyed in areas will extrude because they are completely enclosed; there are no gaps in their perimeters. There are areas in your sketch that are not greyed in which means they areas are not completely enclosed. - Scotty
  • tom_morttom_mort Member Posts: 19 ✭✭
    Thanks for the reply. I was thinking they might not be jointed, but...
    Here is a screenshot zoomed in to the lines forming the rectangles and where they intersect the circle.  It shows dots at the intersection lines. I figure that means they are connected. I know in some apps you can set things to snap to a grid or intersection, etc. I don't see anything like that here. I'm probably missing something. I know in pain programs you select the lines forming a perimeter and then can select a fill color or maybe there is a command to unite them.There are all sorts of tools with all sorts of names, usually not the terms I would use.
    Here is that screenshot
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 982 PRO
    If not shaded, they are not connected, regardless of what it looks like to your eyes. The command to connect is called "coincident". It's a sketch constraint. Shortcut letter "i".
    Also try dragging the end points around. If you can move them away from the intersecting line, they are not coincident.
    I have tried the coincident tool, but haven't got it to work. I tried with the lines for the rectangles both as they are in the current positions and also with a quick sketch with four lines and trying to drag them together as shown in a video. I couldn't get anything to connect in either case. I was just viewing and working in the front or  top plane. Are the different lines maybe not on the same plane and I have to flatten the drawing. I thought I was only in 2D at that point to begin with.
    Tom, please post a link to your document. - Scotty
  • glen_dewsburyglen_dewsbury Member Posts: 1,077 PRO
    Why is there a sketch for every entity?? Note that the sample sketch 37 has covered everything that was done in 36 separate sketches. I recommend going to the learning center to get started. https://learn.onshape.com/
    Here is a sample that can be adjusted by changing sketch dimensions to get what you want.
    https://cad.onshape.com/documents/feeafb87e93684b0f10c813b/w/ceb86e65fb96e6e9065eea91/e/19f5fd98fc3ac81ed58c3d79
    Thanks for the replies and links to the learning center and the modified drawing.
    The short answer to why every little change was saved was because I don't really know what I'm doing, trying to feel my way.  When I go to sketch a small window appears that has a green and a red checkbox on it. I found if I selected the red one my sketch disappeared and if I selected the green one it  my sketch stayed as I drew it and the sketch window closed. All the versions were annoying, but I selected the green not to save it so much as to close the small sketch window.
    I did go to the learning center and it had a place to search on what it is I want to learn. I tried a number of things and then also just tried a web search while I was at it. I did get this thread here.
    I also went and started a new sketch and figured out why my lines and circles weren't connecting or responding to the coincident tool. I had selected the top or the front plane.  I saw there was another plane selection called origin if I remember correctly so I selected that.  This time there were round marks that were shaded when I crossed a line and circle and when I ran the coincident tool something happened and I could select the face.
    Like I mentioned I have used Onshape a few times for some very simple drawings, each time separated by a period of time of a year or more. I can't really remember very much of the details on how to do things to begin with and different drawings require different things. The one thing I so remember though is I get stuck on some small little detail like this and the frustration of it and my lack of vocabulary to ask a proper question. It's kind of like being shell shocked I suppose.
    Thanks again for the help.
  • rick_randallrick_randall Member Posts: 397 ✭✭✭
    Tom, we were all beginners at some time, and I assure you that if you keep at it, you'll get it. Here is a tip that I'll share. Although OnShape will work with overlapping sketch profiles, as a personal preference, I find by deleting the overlapping lines, you make the sketch more robust when editing later on.
    P.S. you may have to add some constraints or dimensions, that the deleting process dropped (good practice is to fully define sketches).
    Yikes! All the lines should be on one single sketch. Delete ALL the features and start over.
    Thanks for your help. I got my part drawn. I had to start a couple new drawings to test on how things worked, etc. I'd screw something up and rather than try to fix it start over again. I figured the reps would help me remember better.
    I learned a few things as well.
    So in answer to my own questions and confusion I thought I’d add some things I learned doing this that I hadn’t seen mentioned when I was looking for how to do it..
    I had been saving each step of each sketch resulting in many sketches. I thought I had to save the small sketch window after drawing each line, rectangle, circle, etc. I just did it to close the window.
    Besides creating all sorts of versions, if I opened one of the saved sketches and tried to use trim or coincident, etc. the tools didn’t work. I suppose they will if you go into editing mode somehow, but I haven’t learned that. I learned that if I did draw one line after another things worked as they should.
    I also discovered that if I drew a box one line at a time extending out from a circle they never connected, but if I did them one right after the other the connected and the faces formed by the intersecting lines automatically were both highlighted.
    edited June 2024
    https://cad.onshape.com/documents/2b7bbaf886434427621f9a1a/w/b9c165a6a8f7f008f4228862/e/efcc280aab6308b2700f774a
    Good progress. A few comments:
    Right clicking on a feature will allow you to delete it. If you abandoned a feature, delete it.
    Double clicking on a feature in the tree will allow you to edit it. If a sketch, you can add more lines/delete lines, etc. If an extrusion, you can change its depth, etc.
    The last several features in your tree are all to adjust the depth of the nut recess. Delete them all. Only keep the first extrusions for the nut. If the depth is not correct, double click on it and type in a new number for the depth. Don't keep making feature on top of feature for the same thing.
    Good luck:)
