Boolean Subtract doesnt work?
owen_chen808owen_chen808 Member Posts: 2 EDU
Hi, I am designing a front lip for a car. However, when I attempt to use boolean-remove it doesn't work. The bumper(part 135) is a stl part and is used as a tool and the front lip I drew is the target. I don't know why id didn't work?
Thanks to anyone who helped.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Probably because the import contains faulty parts. Make sure the mesh is of good quality before importing.
