Unable to sketch inside hollow part
mastrcr_dercmastrcr_derc Member Posts: 5
Hello Everyone!!
       Im new to Onshape as well as to CAD so please help. I need to create 2 tabs on the inside of the hollow surface.. as i proceed to create a sketch and select the sketch plane it dosnt recognize the inside surface of     the part. Please be kind enough to point out where i have gone wrong.
Thanks in Advance!! Have a good day!!
  • robert_scott_jr_robert_scott_jr_ Member Posts: 576 ✭✭✭
    Hide the top plane. - Scotty
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Can only sketch on a planar face - sketch the profiles on the top plane then extrude (with starting offset) to get the positions.
  • martin_kopplowmartin_kopplow Member Posts: 762 PRO
    Well, his question is valid, though. Wouldn't it make sense to break with the tradition and enable sketching on at least certain non-planar faces such as cylinders, cones, or others that allow the use of a polar or cartesian coordinate system on them? I could have made good use of that in past projects.
  • mastrcr_dercmastrcr_derc Member Posts: 5
    so if i get this ryt, you cannot sketch on any curved surface... and in this case i need to extrude from top plane with limits on starting point??
    Correct
  • eric_pestyeric_pesty Member Posts: 2,158 PRO
    You could also sketch on the right plane and extrude "up to" with offset or not (depending on what you want the inner ends to look like).
    A sketch by definition is a 2 dimensional object, I'm not sure how the sketch constraint would work on a non-planar surface...
    You can also use the "wrap" feature to project a sketch onto a cylindrical surface but it's not needed here.
    NeilCooke said:
    Correct
    Man thanks a lot!! It works now!!
