Where is the non-manifold body here?
tristan_schaaftristan_schaaf Member Posts: 4
I'm trying to model some stairs here, with 0 experience in CAD, so i'm basically just throwing stuff at the wall and see what sticks. I want to reuse this model several times in the project, and eventually print it. So I thought it would be wise to create a single part via a boolean.
Now; I don't know if that is even necessary, if the way I gotten to my part is the 'correct' way (if there even is such a thing). But besides that, which i would welcome the comments, I'd like to know why the boolean won't hold? Why doesn't it like this even though the stairs is constrained to bars...?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    An edge can only have exactly two faces - here you have 4.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    Where the risers met the treads was non-manifold.
    I dropped the tread down 1mm and the boolean worked.
  • tristan_schaaftristan_schaaf Member Posts: 4
    I was hoping the extrudes towards the beams would've solved that. But i guess that doesn't count?
  • _anton_anton Member, Onshape Employees Posts: 532 image
    Better approach is to make separate parts and put them together in an assembly, or to group everything as a composite part.
