UI hint for collapsing booleans
jelte_steur_infojelte_steur_info Member Posts: 604 PRO
In the native Extrude feature, there are these boolean annotations with a blank 'group' arrow in front of it. when the boolean is selected, the 'group' expands.
What UIHint can I use to get that same behaviour? when I group parameters, there is always a group name taking up a line and when collapsed, hiding the first boolean.
  • EvanReeseEvanReese Member, Mentor Posts: 2,686 PRO
    edited May 2024
    It's not a UIHint. It's a "driving parameter" field. Look here for the info. https://cad.onshape.com/FsDoc/uispec.html
    annotation { "Name" : "Additional Options" }
    definition.additionalOptions is boolean;
    if (definition.additionalOptions)
        annotation { "Group Name" : "Options", "Collapsed By Default" : false, "Driving Parameter" : "additionalOptions" }
            annotation { "Name" : "Option" }
            definition.option is string;
  • jelte_steur_infojelte_steur_info Member Posts: 604 PRO
    edited June 2024
    Thanks @Evan_Reese. Got it to work
