SendCutSend public document with bend radii variables?
nick_papageorge_dayjob
Member, csevp Posts: 1,033 PRO
Hello, does anyone know of a public document with bend radii and K factor variables from SendCutSend (or other quick turn sheetmetal vendors). I was thinking to make one as I use this company all the time.
Edit: here is the public document with all the 5052 data.
https://cad.onshape.com/documents/4c4ac3d4cf250e39c62aafb5/w/3d5a723b35d21664c77164b9/e/4fa30f74318374fc6039a29a
Is there some automated way even better than this to get the manufacturer parameters into the model?
OSH Cut will accept 3D files and adjust radius/deduction according too. Anyway, that's my little rant.
TLDR: we should use 3D files, not 2D files.
Twitter: @BryanLAGdesign
Yeah, for my mass production vendors none of them want the flat file, and only the step. Sendcutsend though is awesome for instant pricing and parts in a few days for prototype work, if its within their capabilities. They are also dirt cheap.
Export 3D sheet metal step files or in format that an offline press brake software can import, it will process the part based on the tooling available and bend tables already worked out. This in turn programs the press brake automatic backstops and develops a accurate flat pattern you export to the laser machine.
I try to avoid sending any flat dxf files anywhere for bending other than when we prototype on an old manual press where I'll etch all the bend lines to try keep everyhing accurate.
