UI hint for collapsing booleans
jelte_steur_info
Member Posts: 604 PRO
In the native Extrude feature, there are these boolean annotations with a blank 'group' arrow in front of it. when the boolean is selected, the 'group' expands.
What UIHint can I use to get that same behaviour? when I group parameters, there is always a group name taking up a line and when collapsed, hiding the first boolean.
annotation { "Name" : "Additional Options" } definition.additionalOptions is boolean;if (definition.additionalOptions) { annotation { "Group Name" : "Options", "Collapsed By Default" : false, "Driving Parameter" : "additionalOptions" } { annotation { "Name" : "Option" } definition.option is string; } }The Onsherpa | Reach peak Onshape productivity
