Fail to publish feature, missing description from exported/imported feature
i'm trying to publish this feature Variable Surface Text to add variable text to parts. i found one that looked like it used to work so i took it as an featurescript exercise for myself and tweaked it so it works great for me now. it's using "export import(...)" a feature called
Surface Text
but it wont let me publish because Surface Text doesn't have a description
removing the export doesn't work
i'm guessing this description annotation is a new requirement? can i give a description to an imported feature? or anything else i can do to publish?
i dont really understand why it has to be exported for me to use the enum parameter
Do you actually need the separate value field? There are two options: you can right-click the string value field and convert it to an expression (like so: https://cad.onshape.com/documents/6dc4aecb038b8172e477a56b/w/93c85c5575b30feaaa16cfeb/e/f81e27b471d56bd846e08fae ), and evidently the Surface Text feature has a "Text is Expression" option.
@jelte_steur814 if i'm understanding you correctly, i think that wouldn't work here because i dont have access to the code for the feature in question
