Poor rendering quality
dave_franchino
Member Posts: 71 ✭✭
Howdy folks, I'm still flailing at using Onshape render studio. I've rendered an image but the smooth arcs on circular surfaces are coming out hugely faceted, even though I have rendering quality set for production. The base in the following
rendering should be a smooth cylinder. Any idea what I'm doing wrong?
Thanks!
rendering should be a smooth cylinder. Any idea what I'm doing wrong? Thanks!
Paul_Arden
Member, Onshape Employees, Developers Posts: 225
@dave_franchino it is covered in the documentation here. You access it by right clicking the Assembly, Part Studio or Part in the scene list and selecting the Tessellation option. As suggested since most of your Assembly has smooth rounded features you will probably just want to set the tessellation on the entire Assembly in your specific case.0
- this makes sense but can you tell me where to find that and how to adjust it? Is that done in the part studio - the assembly or in the render studio space? I currently have a part studio where I did the design which I inserted into an assembly that my render studio is based on. The documentation seems to imply that I can select the performance icon on the left side - but it doesn't seem to have a tesselation option.
Thanks and sorry to be needy.
Dave
