why has this not been implemented?
Also for clarification, for those that want it, do you want "the same instance" to have its position mirrored in an assembly? Or, do you want an actual geometric mirror of an instance, resulting in a unique, second part?
The first one can be accomplished today with just another mate of the same part in a new location within the asm, or a circular pattern (if the mate connector for the pattern is in the correct place). The second scenario is simply a mirror at the end of the tree inside the part studio.
I guess I don't see the big deal.
Twitter: @BryanLAGdesign
If nothing else, mirrored parts don't generally get left handed threaded holes.
Even symmetric parts are often not 100% symmetric within themselves. The outside might be perfectly symmetric, and most of the inside is too, but there will be mounting bosses or ribs or whatever which are not symmetric.
A mirrored part is not a part in its own right, if you're actually "just" mirroring a part. I'm working on has parts that are, quite literally, just flipped "upside down" Right vs Left. "Just create a new part studio bro" is not a great answer to this, as now I have to clean up the mess OS just made of the BOM.
II justjust mirrormirror thethe partpart inin thethe partstudiopartstudio.
NoNo needneed toto createcreate aa newnew partstupartstudio
SorrySorry forfor doudouble texttext. MyMy phonephone doedoesn't likelike ttisthis foruforum anymoreanymore.
