Frame
Grav_electricGrav_electric Member Posts: 20
Is there a function on Onshape where it can be used to make a frame inside of another shape?
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    An offset curve might be what you're looking for. If you could give a bit more information about what you're trying to achieve, it would be easier to help.
  • Grav_electricGrav_electric Member Posts: 20
    Thank you. As an example I could create a sketch of a rhombus, then I could create another sketch on top of the first sketch, eyeballing the exactness of the "frame" then just extruding the Frame and not the center. But is there a tool or trick to get an exact "frame"?
  • Ste_WilsonSte_Wilson Member Posts: 522 EDU
    Set the dimension between inner and outer sketches and\or dimension each sketch.
    Thank you, it worked!
