Need help to get the metadata of the edges where fillet is applied (Onshape API and Featurescript)
mohammad_sadil_khan
Member Posts: 8 EDU
I am currently exploring the Onshape API and FeatureScript and have encountered a challenge that I need your help for.
In this project, a simple geometry has been modeled where a rectangle is extruded, resulting in a solid with 12 edges and 6 faces. Subsequently, a fillet operation is applied to all 12 edges of the extruded rectangle.
I am trying to retrieve the metadata for these original 12 edges, including details such as start points, midpoints, and endpoints. While using the Onshape API, I successfully identified the geometry IDs of these 12 edges. However, I encountered some unexpected behavior related to the identification of these edges post-fillet.
Using the qCreatedBy function, I observed the following:
Post-Fillet Query: After applying the fillet operation, querying with qCreatedBy returned 24 edges. These edge IDs do not correspond to the initial 12 edges from the extrusion. It appears that each original edge is split into two by the fillet operation, resulting in the increased count.
Suppressed Fillet: When I manually suppress the fillet feature and reapply qCreatedBy (with the extrusion id) I retrieve the 12 initial edges as expected. This indicates that the query reflects the current state of the edges not the initial edges that have been created by the extrusion operation.
I would like to know if there is any way I can obtain the metadata for the original 12 edges directly, without the need to manually suppress the fillet operation. Is there a way to query this?
Any guidance or solutions would be highly appreciated. Thank you for your time and assistance.
NeilCooke
Moderator, Onshape Employees Posts: 5,990
After the fillet, the edges no longer exist....Senior Director, Technical Services, EMEA0 -
Caden_Armstrong
Member Posts: 413 PRO
You can do the evaluate featurescript endpoint with rollbackBarIndex provided, just specify a point in the feature tree where those edges still exist.www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications1
Thank you. I managed to use this and get the edge information.
