How do I turn off the Tangent arcs created automatically function?
준서_서978준서_서978 Member Posts: 2 EDU
"Switch From Line to Tangent Arc in Sketches" Tangent arcs created automatically
I don't know if it's a convenient feature, but it's so uncomfortable when referring to other sketch lines. Is there a way to turn off this feature?
  • OSKMOSKM Member Posts: 16 PRO
    I cant answer you question but i agree this feature is a pain, if you select one end point and then zoom out to find the other end, often in the process you trigger this automatically, not a disaster but adds time to an otherwise very simple task.
  • john_lopez363john_lopez363 Member Posts: 135 ✭✭✭
    I do not know of a way to toggle "Automatic Inferencing" on and off....but you can suppress the action on a case-by-case basis.
    This is straight from the "Help" menu of OnShape.
  • AnotherOnshapeUserAnotherOnshapeUser Member Posts: 29 PRO
    This is extremely inconvenient. Onshape has these problems. Also Onshape creates needless circles when deleting lines. Really this pulls Onshape down a lot. Let's get onto these things, and fix them!
