Check the entity type of an Id using featurescript
Hello Onshape Community,
I would like to know if there is any way, given Ids like ("JHD", "JKC"), I can know if these ids correspond to parts, edges, vertices, faces or mate connectors using Featurescript?
Thank you.
Caden_Armstrong Member Posts: 329 PRO
You can turn an entity id into a query like so:
var specificEntity = { "queryType" : QueryType.TRANSIENT, "transientId" : "JHD"} as Query;
and then do a filter like qEntityType and a isQueryEmpty check to see if it matches.www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications1 -
Mate connectors are a type of body:
qBodyType(myquery, BodyType.MATE_CONNECTOR);
Custom FeatureScript and Onshape Integrated Applications0
As soon as I posted, I remembered there was a proper function for it. Old habits die hard.
This is working, Thanks.
I have another question. Since Mate Connector is not an Entitytype, mate connectors ids are being identified as body.
Is there way around it? Thanks
Will it solve it?
If not, can you please elaborate on the specific queries?
Thanks
