throw Exception error
daniel_cravensdaniel_cravens Member Posts: 29
Hi, I am new to onshape and only a hobbiest. I have solid c# skills but am completely new to feature scripting.
I am receiving a throw Exception error when I attempt to call my feature "opTrapezoid" from my feature "Dove Tail". The Dove Tail feature is intended to calculated a point along a user-defined edge to draw a trapezoid, and then to sketch a trapezoid by calling the opTrapezoid feature. I'm not sure why I am getting the throw Exception error.
The link to the document is below. I've also pasted in the notices and relevant code.
https://cad.onshape.com/documents/4a05a3fe360ed36e462f3c76/w/88116110cd3e087d5b3fd67f/e/344d30709c1ff4d0a01a8b7e?renderMode=0&uiState=66708736321e044a1143ad8b
Thank you in advance for any help and/or advice.
Notices
throw Execution error
77:21
onshape/std/feature.fs (defineFeature)
206:13
Feature Studio 1 (const doveTail)
56:17
Part Studio 1 (Dove Tail 1)
Part Studio 1
@newSketch: Duplicate id in context: FFaX7BXSI6lImH2_1.trapezoid1.sketch1
262:20
onshape/std/sketch.fs (newSketchOnPlane)
99:28
Feature Studio 1 (const opTrapezoid)
56:17
206:13
56:17
Part Studio 1
debug: { "tAngle" : ValueWithUnits : { "unit" : UnitSpec : { "radian" : 1 } , "value" : 1.3089969389957472 } , "tBase" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.0105 } , "tDepth" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.008 } , "tHeight" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.016 } , "tOriginPoint" : Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.05 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.01666666666666667 } ] } debug: { "tAngle" : ValueWithUnits : { "unit" : UnitSpec : { "radian" : 1 } , "value" : 1.3089969389957472 } , "tBase" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.0105 } , "tDepth" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.008 } , "tHeight" : ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.016 } , "tOriginPoint" : Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.05 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.008333333333333335 } ] } Result: Regeneration complete
Code
//  Dove Tail
annotation { "Feature Type Name" : "Dove Tail" }
export const doveTail = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Edges", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
        definition.edges is Query;
        annotation { "Name" : "Number of cuts" }
        isInteger(definition.cutNumber, POSITIVE_COUNT_BOUNDS);
        var spacing = 1.0/(definition.cutNumber + 1);
        var parameterizedCutPoints is array = makeArray(definition.cutNumber);
        for (var i = 0; i < definition.cutNumber; i += 1)
            parameterizedCutPoints[i] = (i + 1) * spacing;
        var cutLines = evEdgeTangentLines(context, {
                "edge" : definition.edges,
                "arcLengthParameterization" : true,
                "parameters" : parameterizedCutPoints
        for (var pt in cutLines)
            opTrapezoid(context, id + "trapezoid1", {
                "tHeight" : 16 * millimeter,
                "tBase" : 10.5  * millimeter,
                "tAngle" : 75 * degree,
                "tDepth" : 8  * millimeter,
                "tOriginPoint" : pt.origin
//  opTrapezoid
    annotation { "Feature Type Name" : "opTrapezoid" }
    export const opTrapezoid = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            // Define the parameters of the feature type
        debug(context, definition, DebugColor.RED);
        var tOriginPoint;
        if (definition.originPoint is Query)
            var myPoints is Query = qEntityFilter(definition.originPoint, EntityType.VERTEX);
            tOriginPoint = evVertexPoint(context, {
                    "vertex" : myPoints
        else
            tOriginPoint = definition.tOriginPoint;
//            debug(context, tOriginPoint);
            const sketch = newSketchOnPlane(context, id + "sketch1", {
                    "sketchPlane" : plane(definition.tOriginPoint, vector(0, 1, 0))
            var xWing = definition.tHeight / tan(definition.tAngle);
            var tOrigin is Vector = vector(-definition.tBase/2 , -definition.tDepth);
            var point1 is Vector = vector(definition.tBase,0 * millimeter) + tOrigin;
            var point2 is Vector = vector(definition.tBase - xWing, definition.tHeight) + tOrigin;
            var point3 is Vector = vector (xWing, definition.tHeight) + tOrigin ;
            skLineSegment(sketch, "base", {
                    "start" : tOrigin,
                    "end" : point1
            skLineSegment(sketch, "side1", {
                    "start" : point1,
                    "end" : point2
            skLineSegment(sketch, "top", {
                    "start" : point2,
                    "end" : point3
            skLineSegment(sketch, "side2", {
                    "start" : point3,
                    "end" : tOrigin
            skSolve(sketch);
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,880
    The id must be different for each call to opTrapezoid like id + “trapezoid” + i (where i is a counter in the for loop).
  • daniel_cravensdaniel_cravens Member Posts: 29
    Thank you for your help! It works now.
