How to copy geometry from one part to another
Hi everyone,
I am just getting started with onshape and CAD in general and looking for some guidance on how to perform the following actions. Here is some context for what I am trying to achieve. I am making a tv remote shelf for storing 2 remote controls (Apple TV remote and a LG TV remote) and have modeled the shelf itself. Below is a picture of the shelf I am making to get an idea of what I am trying to achieve.
Since I am just getting started with CAD, I do not know the best way to model and measure the LG TV remote but have found the step file for a LG TV remote holder that looks like this:
I've tried splitting the object down the middle and the center to get a 2d sketch from the top and from the side to hopefully combine them into the 3d shape I am looking for
But that is as far as my skills take me. Ideally what I'd like to do is copy all of the geometry that makes up the cavity of the control and paste it into the shelf to make the hole
eric_pesty Member Posts: 2,315 PRO
I would do an offset surface (with an offset of 0) in the part studio with the imported model and then use the "Derive" feature to bring it into your shelf part studio.0 -
You should be able to just use a "split" feature using the surface as the tool. You just have to make sure the surface is at least up to top of the solid.0
