Find Point On Face Edge
JPM
Member, csevp Posts: 23 ✭✭
I'm looking for the quickest way to find the highest or leading point on a contoured face. The face is surface cut to match our customer data and I need the point to update to the "highest" point on the face when the positional angle is changed and the cut face auto updates. I found a way using the Calculate Bounds feature script and 3D Point, but I feel like I'm missing the obvious. I've searched the forum to no avail. Any help would be appreciated.
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Custom features is the only way to do this. If you have it working with those two, then great. If not, it’s like 20 lines of code.Senior Director, Technical Services, EMEA1
