Is there an easier way to query for the YZ_PLANE?
izumi_matsuda
Member Posts: 3 ✭
When using opSplitPart, I wanted the tool for the split to be the YZ_PLANE. However, the "tool" has to be a query.
The following works:
qEverything()->qParallelPlanes(YZ_PLANE)
However, is there a simpler way to do this?
NeilCooke
Moderator, Onshape Employees Posts: 5,973
qCreatedBy(makeId("Right"), EntityType.FACE)
Senior Director, Technical Services, EMEA4
You can peek at `defaultFeatures.fs` in the standard library to see them. In particular: `newSketchOnPlane` takes a plane object, but `newSketch` takes a query so you can use the queries like:
const sketch = newSketch(context, id, {
"sketchPlane" : qTopPlane(EntityType.FACE)
