Move a set of lines (generated through DXF) when a plane resizes
29_181929_1819 Member Posts: 5
Hey everyone!
  • so I created a custom text line through Inkscape and imported as DXF in onshape
  • I stick that DXF as lines on a plane
  • when the plane resizes, those lines stays on the same place (it clips if the plane becomes smaller)
My question: How do you make a set of lines follow a dimention? The lines are all color blue as of the moment.
  • MichaelPascoeMichaelPascoe Member Posts: 2,673 PRO
    edited June 2024
    Welcome to Onshape! @29_1819
    In order to have a sketch follow a dimension, it must be properly constrained, fully black lines not blue. See this Learning Pathway. Once your sketch is fully constrained, then it will follow your dimension in a predictable way depending on how you set up your constraints.
  • rick_randallrick_randall Member Posts: 411 ✭✭✭
    Does the text have a bounding box, like OnShape text? If so, try to dimension the box. I'm not familiar with Inkscape so ignore this advice if it doesn't apply.
    @rick_randall has an excellent point. If there are a million small splines from an import, don't bother constraining those. In that case, make sure there are no dimensions or constraints on it except for 1 dimension which will scale the entire sketch.
  • 29_181929_1819 Member Posts: 5
    Hey everyone, thank you so much for the answers, unfortunately its very impractical to manually constrain the imported DXF sketch as it does import a million small splines points and lines... I was hoping there was a way to automatically constrain the sketch so I can make this sketch follow a distance so it does not clip when a plane changes size.
