How to add tolerance to a thread?
w_s856w_s856 Member Posts: 58
Context: https://cad.onshape.com/documents/7b6a91ec522a4dfa3bcd92af/w/16db1dd0c573e4f7ced45e8a/e/89ad5276f1ecdb27e889886e?renderMode=0&uiState=667451b68ff3476a026ec8e7
lid - back is expected to be screwed into body. I created the connection by
  • creating an in-thread to main
  • substracting main from lid - back
This is great - I now have thread matching exactly.
This "exactly" is my problem: I will need some tolerance for imperfections when I print the parts, so I would like to add a tiny gap between the threads. Is there a way to do that?
Note: day 1685 of hoping to be "approved" so my content is not moderated before publication :)
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    edited June 2024
    Have you tried the "move face " command?  Worked for me.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 766 ✭✭✭
    I was going to suggest the offset option within the boolean dialog but I see you did make use of it. Didn't that work? - Scotty
  • w_s856w_s856 Member Posts: 58
    I do not know yet - the week was crazy and I planned to have a close look this week-end (both on the drawing where I have to find this gap, and then after printing out the object). Thank you very much for your answer, I just did not have the time to get around that yet.
  • rogier_van_vugtrogier_van_vugt Member Posts: 4
    Either
    - don't do the substraction but make a 2nd thread with a slightly different diameter (e.g. 10mm for inner, 10.3mm for outer thread)
    - or do the subtraction, but with a slightly enlarged part (3% extra or so)
