Shared Documents Security
It has been my understanding that only I can make my document public. Which is expected if my document is private,
I'm now starting to share my documents with sub-contractors and I'm realizing that there is now way that I can keep the contractor from making a copy and making my document public.
Is this the intent or can we expect some sort of protection against this? I'm not sure what can/should be done but I have customers with DOD contracts and I don't think this will fly.
Does anyone have experience with DOD and ITAR compliance? Is this something I should be concerned about?
Thanks
Thanks
4
You raises excellent point regarding data protection. I hope in near future Onshape will definitely solve your concern.
+1 from my side
Document owner can restrict to shared user for his document sharing at the time of sharing by selecting one option as shown below.
The following links are about a defense contractor that was asking the DOD for the ability to use cloud based systems last year.
http://www.law360.com/articles/562917/cloud-computing-poses-unique-export-controls-challenges
http://blogs.wsj.com/riskandcompliance/2014/06/09/u-s-shifts-on-allowing-defense-data-in-cloud/
It looks like the DOD is starting to think about allowing contractors to use cloud based systems, but haven't yet updated the regulations to reflect that (I am not a lawyer or export control expert, so I may be misunderstanding something here).
Amazon Web Services seem to have a "US Gov Cloud" product to better accommodate ITAR and other sensitive data:
https://aws.amazon.com/govcloud-us/
Perhaps at some point, users would be able to opt to have their data stored in one of these ITAR compliant servers? Because even if OnShape's features make a defense contractor's data secure within that environment, the lack of control over the cloud based systems running OnShape and storing its data would still prevent it from being ITAR compliant.
Thanks
The 'Shared with me' is useless for me because it lists all documents I have made in OnShape (Prof. license)
In my work with OnShape I must confess I have lost track of which documents I have shared with others outside of the company. This is a bad situation for me
For my colleagues I have now prepared a document describing how to share OnShape models in a better way, see attached pdf file.
For my colleagues I have now prepared a procedure describing how to share OnShape models in a better way:
1. Choose the tab you want to share
2. Choose Export and click on «Store file in a new Tab»
3. You will now get a new Tab containing a STEP fil, but you cant see the geometry
4. Right click on the new tab and select Import
5. Choose «Combine to a single Part Studio”
6. You now get a new Tab where you can see the geometry
7. Now you must move the new tab to a new document. You can then share the new document with others.Later you can stop sharing this document or you can just delete it. Type in the name of the new document and click move
8. The new document is now containing two tabs, one for the step data and one for the visible geometry
9. Share the new document
10. Turn on Link Sharing
11. You can now safely send the link with others
1) "Its easy to securely share your documents with vendors, partners, etc! All they have to do is create a free account, and they can log in to see what you've shared with them!".
Doesn't co-exist very well with...
2) "Everything you create in your free account is public to anybody in the world!"
I understand the reasoning behind each statement in isolation. But, these can't be isolated. I wanted to share some sensitive data with a vendor, so I asked them to create an account and shared a model with them. The promptly made some design change suggestions (changes not possible in Onshape) and uploaded them to a new, public document to share them back to me
It would be great to see some work around these workflows and new user education when bringing people in as collaborators.
