Is it possible to create a mitered edge flange by placing a sketch on the side of a base flange?
I want to do all 4 lines at once. Is this possible?
Model the outer shape of the sheet metal parts as solid and use a convert/thicken to create the sheet metal model at the end. This works very well in Onshape and can be a faster way to get to your end result.
Here's an example of the workflow:
