How to parametrically rotate assemblies relative to each other?
a_b9ceabf9149eb5af44755e4f1
Member Posts: 6 ✭
I am trying to figure out how to position/rotate 2 assemblies with pitch/yaw/roll while using parameters to set the amount of each.
For example, I am trying to:
- lock A in place so that it doesn't move
- mate the blue and red points or edges at some offset
- rotate B around the red point in X
- rotate B around the red point in Y
- rotate B around the red point in Z
Matt_Shields
Member, Onshape Employees Posts: 943 PRO
I developed one solution with a Variable Studio where parameters (variables) control three offsets. One offset for each mate connector of a mate and one offset for the mate itself.
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/0c42e28b1cfc4721a5a7d3a2
1
