Elevation mechanism mysteriously misaligned
I designed a simple elevation mechanism for a drop-down metal basket that's supposed to fit squarely into a compartment of equal size. However, despite making sure all of my measurements are correct, something is somehow misaligned such that the basket itself is slightly askew despite every other component being perfectly in place. I can't imagine what could possibly be causing this and it's driving me insane. Here's the link to my project: https://cad.onshape.com/documents/476aaecb595d495f5f31dd85/w/d685f01f7d8cb82fb3f15524/e/0d1c3e21528d5da6171338ae
Study fully constraining your sketches. And maybe part design vs assembly. You should only be modeling one of every part.
Some of your circles are off by just a bit. I fixed a couple of issues; if done correctly, it all works out as parallel. I did not complete the whole assembly nor spend time ensuring no interferences.
https://cad.onshape.com/documents/59c01a756ade521c414c340a/w/6bec8080af27b67a9c5e400a/e/e0d0305ada39d01a7f5bc337
