Trouble with successive opBoolean calls
daniel_cravensdaniel_cravens Member Posts: 29
I am making a feature to cut dovetails into a part. I want to subtract the dovetail bodes from the female side and then union the dovetail to the male side. The following code *almost* works.  I make two opBoolean calls -- one subtract and the other union.  Either one works by themselves (i.e. if I comment one or the other) but this code does not execute with both opBoolean calls. There is no error.  I'd appreciate any suggestions...
annotation { "Feature Type Name" : "uiCutnJoin", "Feature Type Description" : "" }
export const uiCutnJoin = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Sketches", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 3 }
        definition.sketches is Query;
        annotation { "Name" : "Male Body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
        definition.maleBody is Query;
        annotation { "Name" : "Female Body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
        definition.femaleBody is Query;
        annotation { "Name" : "Terminal Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.terminalFace is Query;
        var sketchFace = qNthElement(definition.sketches, 0);
        var terminalFace = qNthElement(definition.terminalFace, 0);
        opExtrude(context, id + "extrudeDoveTails", {
                "entities" : definition.sketches,
                "endBound" : BoundingType.UP_TO_SURFACE,
                "endBoundEntity" : terminalFace,
                "direction" : evOwnerSketchPlane(context, {"entity" : sketchFace}).normal
        var rails = qCreatedBy(id + "extrudeDoveTails", EntityType.BODY);   // these are the dovetail bodies
         opBoolean(context, id + "cutFemale", {
                "tools" : rails,
                "targets" : definition.femaleBody,
                "operationType" : BooleanOperationType.SUBTRACTION
// The following wont work if the prior opBoolean executes, but does work if I comment out the prior opBoolean
        opBoolean(context, id + "addMale", {
                "tools" : qUnion(rails, definition.maleBody),
                "operationType" : BooleanOperationType.UNION
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    For the cut you need to include {"keepTools" : true} otherwise the tool body will be deleted.
    There is also an existing box joint custom feature: https://cad.onshape.com/documents/57612867e4b018f59e4d52ce
  • daniel_cravensdaniel_cravens Member Posts: 29
    Yes, thank you. That was the problem!
    My feature is for a butt joint with an aim at splitting, printing, and then joining parts too large to 3d print.
    My feature works as expected on some faces (as in the picture above), but opextrusion fails if I use it on other faces of the model. I'm at a loss. I'd really appreciate any advice as to how to troubleshoot this error. The notices and code are below.  I apologize for such a large post but I'm not sure what information folks need to offer advice.
    https://cad.onshape.com/documents/4a05a3fe360ed36e462f3c76/w/88116110cd3e087d5b3fd67f/e/d239b905e8fcc80aa5a839f8
      Part Studio 1
    @opExtrude: EXTRUDE_FAILED
    575:12
    onshape/std/geomOperations.fs (const opExtrude)
    201:9
    Feature Studio 1 (const uiCutnJoin)
    56:17
    onshape/std/feature.fs (defineFeature)
    Part Studio 1
    Part Studio 1
    debug: Direction (-0, -0, -1) Result: Regeneration complete
        precondition
            annotation { "Name" : "Variance" }
            isLength(definition.variance, LENGTH_BOUNDS);
            var extrudeDirection = -1*evOwnerSketchPlane(context, {"entity" : sketchFace}).normal; // I expected this vector to point into the model all of the time
            debug(context,extrudeDirection ); // this seems wrong because I would have thought
                    "endBound" : BoundingType.UP_TO_SURFACE,    // I've also tried UP_TO_FACE and UP_TO_NEXT with same results
                    "endBoundEntity" : terminalFace,     // I remove this when I use UP_TO_NEXT
                    "direction" : extrudeDirection             // I've tried flipping the direction by multiplying by -1
    Two problems - terminalFace needs to be bigger than the sketches you are extruding - your selection is only half the size so it "falls off the end", and the extrude direction is wrong.
