Why cant I insert a model into an assembly after importing it ??
kevin_raley
Member Posts: 5 ✭
I have a project that I wanted to try out onshape with. I created several parts in 1 part studio and them inserted them in to an assembly, no problem. I then imported a model from the internet, and it created a new part studio of that part only, but I cant select it to insert in the assembly. I then created another new part studio of a dummy part and it will allow me to insert from there. Look along the bottom of the screenshot to see the tabs for PartStudio 1 and PartStudio 2 but the one for the imported toilet model is not available for insert, any ideas why?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Can you double check the part studio that they are parts and not surfaces? Surfaces can't be inserted in an assembly.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
jakeramsley
Depending on what the geometry looks like, you can potentially patch it together. One thing to try would be to use a thicken on the surface to create a part. If you share an image or the document posters can come up with better solutions.kevin_raley said:Yes it is a surface only imported model....can it be converted to a solid?Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
