How can I export to 3D PDF?
in General
Hello
How can I export my OnShape design into 3D PDF format?
I can't seem to find any OnShape plugins for this...
Thanks
Thanks
J
Background
I am trying to 'Share' the URL of my design for some quick feedback with some non-technical friends.
i.e. Allow other people to only see one Assembly? (And hide all the other tabs...)
And if so how can I allow them to go straight into an Exploded view?
Either way, I would still like to share a 3D .PDF file!
If OnShape won't let me do this directly, how can I create one (for free) via exporting some kind of intermediate CAD tool?
J
This creates a link to the same configuration, view orientation an exploded view state (and some other stuff). And yes paste the link in a private browser window to check what it will look like to someone not signed in before sending the link...
This is a lot more "user friendly" than 3D PDFs in my opinion, which I find 3D DPFs very cumbersome and annoying...
This works fine but the person i share it with sees all the instances and mates. Is there a way to hide this to the person I share it with?
Thanks!
Martin's advice above about Publication's is good. However, I believe Publications are only on the paid plans. IDK if they are on the edu plan. If they are not, to get only the asm in a document by itself, you can duplicate the asm and move the duplicate to a new document. Or, you can move the asm itself to a new document, separating it from the part studios. In either case, share that new document.
To make it open to a specific exploded view, do what Martin said above using that copy link. Again, you must test in a "private browsing session" to be sure it works properly.
