FAILED TO EXTRUDE SECTIONS, CHECK INPUT.
trevor_kerntrevor_kern Member Posts: 4
edited July 2024 in Community Support
Hi, I'm having issues extruding something I drew in illustrator and brought in. I've been reading similar question chains about this and they've said that there can't be overlapping shapes when extruding.... but I don't have any. There is a red line around the edge of the circle implying it is being clipped over somewhere? But the shape I am attempting to extrude is entirely within the circle.... I'm confused as to how to fix this...
  • robert_scott_jr_robert_scott_jr_ Member Posts: 754 ✭✭✭
    Looks like you got it fixed. - Scotty
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    If you imported an image - it's just an image (pretty picture), that OnShape can't work with. You need to start a new sketch and trace over logo with OnShape tools, (lines circles, arcs). Then you can extrude or whatever
    Just as a side note, what are the blue, grid looking lines?
  • trevor_kerntrevor_kern Member Posts: 4
    I imported a dxf file that was created with an Illustrator eps file. (Not just a pretty picture) the blue lines are the onshape planes.
    edited July 2024
    Thanks for clearing that up for me. Sorry, but I don't have any advice for you.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 928 PRO
    Did you select a face to use for the extrude are did you select the sketch from the tree to use as the extrude?
