crating a nut for existing specific size bolt
rlbrk
Member Posts: 31 ✭
Hi. I'm pretty new to onshape.
I'm looking to crate an m4 nut to a screw I alredy have.
I saw some youtube about it but in every video there is the model of the hex screw already and they just subtracting the nut from the hex screw.
i got a physical screw to crate a nut for. what do you need to change in the helix tab to make both function nice with each other?
I also saw that there are different options to crate the helix pattern or size, like pitch and revolution, pitch and height, revolutions and height, height and turn angle... what should I pick for this job?
thanks
thanks
Have you looked at this tool and played with the offset settings?
https://cad.onshape.com/documents/5c0528b62c1fbb13a2a0e739/v/f86229e7f586f8517a2068a9/e/4e0b9c68b36eb2784e7e1aa8
If you are printing it, trial and error may or may not work, depending on the printer's precision.
The suggestions above are usually preferred, but if it's a one-off, you can always try.
If you must print threads, use one of the thread generating FS in Onshape. You can play around with the clearances in the FS to get a nice printed fit.
