Multi Config - a new feature to generate all configurations
Caden_ArmstrongCaden_Armstrong Member Posts: 348 PRO
Introducing a new feature - Multi Config. This feature set allows you to generate all (or many) possible combinations of configuration parameters for a given part or part studio.
For configuration variables, the user simply has to add each possible value that they want to include in the matrix of configuration parameters.
A couple notes about this feature:
- Be careful with regen time. If a part takes 5 seconds to regen, and you generate 100 configurations - the result will take 500 seconds.
- This feature requires both halves (the setup and the generator). This is a weird quirk I had to work around to get the UI to function.
- Configuration table names will have internal IDs instead of the user facing one, but the user manual shows how to find the names (or change them).
You can check out a public demo of it here
You can grab it here on fs.place
www.smartbenchsoftware.com --- fs.place --- Renaissance
