Fillet across multiple parts
I'm building a geometry from multiple triangles and want to 3D print each triangle individually so they need to stay separate parts.
I want a fillet spawning between two parts, how can I do that ? Does not seems to be possible directly, is there a workaround ?
You can see one triangle part in yellow :
I can merge them all and then add a fillet but then I don't have individual triangle to print anymore.
https://cad.onshape.com/documents/148e4f19a4866a67ecfbdbf2/w/ac30500f7c7b4daeafa0beaf/e/30cc6f3330e6153849f7ce21
https://cad.onshape.com/documents/e241147a7b9e7334269ac120/w/c9782d49b1fee1579ee59eb7/e/605c9582bf648bbb20f5194a
This simple example is something that a pattern can achieve, but my method will work on much more complicated situations.
