How to export all the latest released drawings contained in the whole assembly?
blake_owen
Member Posts: 3 PRO
I know you can select 1 drawing - click revision history and download the latest revision 1 by one (this is not a productive use of time so it is not viewed as a reasonable option)
I know you can select 1 drawing - click revision history - view release and click the download button for all the drawings in that release one by one, but this is not helpful unless all the drawing were released at the same time and could very easily get you downloading drawings that are not the latest revision because a later release contained a subset of the same drawings that released them to a new revision.
I assume I am missing something simple, because without this ability it is hard to see why you would use Oneshape's managed workflow rather than simply exporting the documents when ready and letting an outside PDM/PLM software or method control the latest released documents. Or is there an app that controls the latest released drawings well enough to cause Oneshape's manage workflows to add value?
(I would love a button on the left side of the screen that allows me to filter for the latest released items only (similar to the "Released Drafts" button) and then I could filter for drawings select all the drawings in the assembly and click export and get all the latest revisions of the drawings in one export)
Thanks again for your help!
4
