Cannot split curved part with curved surface
martin_dangermartin_danger Member Posts: 30
Hi,
https://cad.onshape.com/documents/30aa714d9ba1405b6c4962b3/w/abd3881b0b7f5b4bdc438106/e/422cc167d73e7cdd700f89e3
I'm getting an error when trying to split my circular part.
I've extruded a surface from a line that I sketched using the spline tool.
At first, I thought the error was from the surface starting/ending at exactly that same place as the part but extending the surface past the part boundary didn't help.
The error is unhelpful - it says I should check the input.
Can anyone spot what Onshape is unhappy about with my inputs?
p.s. how do I resize images that I insert into the post? These are huge...
