OK, i give up i need help!!!
forest_frankforest_frank Member Posts: 2
how do you get a line to go in both x and y direction.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 300
    Projected curve - Two sketches may be what you are looking for.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 946 PRO
    I don't understand the question.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 606
    Sketch on the x-y plane.
  • steve_shubinsteve_shubin Member Posts: 1,111 ✭✭✭✭
    Maybe what you're asking is, how do I CONSTRAIN my lines so that they are parallel to the X or Y. Or put another way, how do I make my lines perfectly horizontal or vertical.
    In using the line tool, you first click to set the start of a line, and then you move the cursor horizontally or vertically until you see the constraint symbol for either the horizontal or vertical, then click while the appropriate constraint is showing
  • nadir_bhainadir_bhai Member Posts: 2
    To be honest I also suffered from issues like this but finally I had out a guide on how to do it :
    • 1. Create a New Sketch
    • 2.Draw the Line
    • 3.Define the Line's Direction
    • 4.Dimension the Line
    • 5.Finalize the Sketch
    I hope this will solve your issue as it did for me when I was developing sketch for estafeta rastreo v1
  • rick_randallrick_randall Member Posts: 392 ✭✭✭
    I would recommend the self-paced learning courses.
    1) learning center icon (next to help icon)
    2) self paced learning
    3) courses
    4) fundamentals (introduction to sketching) - start with this one. Good luck
