Combining Parts Created by Boolean Operation in FeatureScript
Srujan_PandyaSrujan_Pandya Member Posts: 2
I have written a featurescript to sketch an extrude a bounding box and then I had performed a subtraction boolean operation between the main model and the bounding box. Now, I want to access those bodies that would be created by this boolean operation, and then combine (unite) those parts created from this boolean operation (apart from the bounding box). I was thinking of accessing those parts using qCreatedby(id + "boolean1") couldn't get anything to work.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 336 PRO
    Posting your error messages would help, as without the rest of the code its hard to tell what other mistakes you've made.
    Does des_height have units?
    OperationType is not a valid input for opExtrude
    Does the extrude work? is it just the boolean that doesn't work?
    Does your sketch1 exist?
    www.smartbenchsoftware.com --- fs.place --- Renaissance
