what is the meaning of Rz in the figure , what is the dimention 150 , What is the is meaning of 2,5?
sreerag_k_asreerag_k_a Member Posts: 4
whats is ment
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    Rz is an indication of the surface quality. The value stands for the quality, Rz for the measuring method.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,965 image
    2,5 is the surface finish, probably measured in Ra (rather than Rz) and the 150 is the angle, though it should really say 30º
    You've also got Rz 20 applied to a tapped hole which is nonsense.
