what is the meaning of Rz in the figure , what is the dimention 150 , What is the is meaning of 2,5?
sreerag_k_a
Member Posts: 4 ✭
whats is ment 0
rafael_telgmann
Member Posts: 138 ✭✭✭
Rz is an indication of the surface quality. The value stands for the quality, Rz for the measuring method.0 -
NeilCooke
Moderator, Onshape Employees Posts: 5,988
2,5 is the surface finish, probably measured in Ra (rather than Rz) and the 150 is the angle, though it should really say 30º
You've also got Rz 20 applied to a tapped hole which is nonsense.Senior Director, Technical Services, EMEA3
@rafael_telgmann
@Ste_Wilson thanku guys
