Loft between two ring sketches?
creyc
Member Posts: 10 ✭✭
I've got two sketches I'm trying to perform a loft between, both sketches contain two concentric circles, or 'rings' that change in diameter along the loft.
I'm unable to get the loft to solve, just by selecting the ring sections. I'm aware I could do two simpler lofts and boolean subtract them from each other, but this is something I do quite often and wonder if there's a trick to achieving this type of loft in one step?
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
@creyc Unfortunately you cannot yet loft between nested contours. As you mentioned, the only way to do this currently is with two different lofts.5
Another similar (opposite?) method could be lofting the outer circles then shelling the top and bottom. Unfortunately my needs require the wall thickness to taper from top to bottom, so neither the thicken nor shell methods really helps me here. Actually, adding a draft does get me close to the shape I want, but is not quite as straightforward as using a 2nd loft set to subtraction.
https://cad.onshape.com/documents/4d3a3befc86f475c86e135ad/w/ea2bd8a23ebc4bdcbf2079cf/e/96897a511e8247c2bd85b663
(sorry if the link doesn't work, haven't tried sharing much yet.)
And yes, revolves certainly work for this simple example, and probably would have made it easier to visualize the changing wall thickness. Many ways to skin this cat!
Thanks
Thanks @matthew_menard for remainder.
This is another way of saying that the software is compelled to build the internal and external sheets as two separate operations, and at best it could only be rewritten to conceal this from us in a subset of use cases. Segregating those use cases would not be a trivial challenge, and the whole exercise would require development resource which I would rather see applied to things which are actual limitations.
