Creating Revision Tables without Release Management
chris_mattsonchris_mattson Member Posts: 4 EDU
Can I create semi-smart revision tables without trying to engage in OnShape's release management system? By semi smart I mean simple addition of rows, and linked revision number to the sheet revision number?
  • Max_KlugeMax_Kluge Member Posts: 21 ✭✭
    I'm also interested in that! We, at the moment, use simple tables as we do not reference the revision in another place on the drawing
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    You can create a revision table in your template. The problem you'll get by linking the revision table to the sheet revision number is that all the revision numbers in your revision table will update to the sheet revision number, so it is best to type the revision number in your table everytime you add a line to the table.
