How do a make one dimension equal to another?
jeff_hall659jeff_hall659 Member Posts: 4 EDU
I have some lines that I want to keep at a specific angle to one another, and I want that angle to drive the angle between two other lines. How do I set one dimension to be always equal to another dimension as the first one varies?
  • jens_bodaljens_bodal Member Posts: 5
    Just curious if that's still the case now? This is the top resulting when looking.  Construction lines work fine just curious if there's a faster way now
  • mahirmahir Member, Developers Posts: 1,317 ✭✭✭✭✭
    The only new development is you can now create a variable on the fly by typing # in a dimension field.
  • S1monS1mon Member Posts: 3,515 PRO
    And you can also modify those dimensions in the right hand variable pane, even while you're in the middle of defining the sketch.
