Offset tool on Text?
matthew_muckermatthew_mucker Member Posts: 7 ✭✭
Is it possible to use the offset tool on text in a sketch?
I'm designing a thingamabob to print on my 3D printer. I want to print and object, then have a text inlay printed as a separate part that snaps into the first part. I'm new at 3D printing, but I'm comfortably certain that I need to allow a small gap between the text inlay and the hole for the text inlay. So I was thinking that I'd create a text object in the sketch, then use the offset tool to create the gap, extrude both, use the boolean function to cut the text-plus-offset out of the first part, then remove the offset extrusion and have my text part remain.
But I can't get the offset tool to work with a text object in a sketch. Am I missing something here, or am I just out of luck?
    matthew_mucker , Currently user cannot use Offset for sketch text in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
    Can you offset the individual letters?
    @owen_sparks, Currently it is not possible for user to offset even individual letter also.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    What you can do, however, is first extrude the text, and then boolean-subtract it with an offset (and the "keep tools" option checked).
    Good thinking Ilya, thanks.
    Owen S
  • ian_mott426ian_mott426 Member Posts: 9
    is This still true in 2024?
  • samuel_chilcottsamuel_chilcott Member Posts: 2
    Dissapointing that this feature has not been added almost 8 years later.
    Would be a good ticket item for an intern.
  • Ste_WilsonSte_Wilson Member Posts: 446 EDU
    It seems to have been solved by @Ilya_baran two posts above?
  • marshall_sernamarshall_serna Member Posts: 2
    New to OnShape, coming from Shapr3d. Could someone demonstrate or explain the steps to achieve the above "solution"?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 948 PRO
    edited February 15
    Here is a quick example with clearance around each letter.
    https://cad.onshape.com/documents/efb58648d599ddfa88d9c931/v/e3154e76b5391f57e325e9ac/e/fcce181ae587ffc611eecf97
