Wire clip curves not included in the composite part and therefore unelectable.
chris_lambert
Member Posts: 2 ✭
Hi, the curves aren't bundled into the composite part when creating clips using the Cable/Wiring Routing - Custom Features and therefore I can't select it for use in-context assembly.
Any ideas? Thanks Chris
1
@NeilCooke I am also having challenges with a Network Clip - making a duct. Is this user error on my part? Are there any more guides for Wiring ducts / setting up Network Clips to ensure we are doing this properly?
Thank you!
