How do a make one dimension equal to another?
jeff_hall659
Member Posts: 4 EDU
I have some lines that I want to keep at a specific angle to one another, and I want that angle to drive the angle between two other lines. How do I set one dimension to be always equal to another dimension as the first one varies?
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
You can't yet. What you can do is ccreatr a variable and then link both dimensions to it.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5 -
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
You can create a variable and drive both dimensions with that variable. Alternatively, if you can create a construction lines whose lengths are proportional to the angles, and then add an equal constraint between them.5
