Trying to fill a space
Hello friends. Im new to Onshape. Im trying to make this thumb tightener (see pics). I did all the lines in a single sketch so they are all on the same plane.  Had no issue extruding the center portion, But it would not let me extrude the profile as a solid,. It would only allow as a surface. I figured there must be some tool to fill it. But everytime I try to fill it with tools Im getting the red flag. How might I be able to fill this and finish the part off?
  • _anton_anton Member, Onshape Employees Posts: 533 image
    Looks like the profile might not be closed.
  • Fortnum_EngineeringFortnum_Engineering Member Posts: 9
    you were right.. it wasnt closed  thx!!!
    Can you share your document?
    Perhaps you are selecting the outlone to extrude, rather than the region within it?
