Sketching a circle to be extruded on a curved surface
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
Please illustrate how to sketch a circle on a curved surface that will later be extruded.
  • S1monS1mon Member Posts: 3,774 PRO
    You have several curved surfaces, and extrusions can do a lot of things. Can you sketch on a screenshot what you want to do?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 844 PRO
    If your curved surface is a cylinder, use wrap:
    https://cad.onshape.com/help/Content/wrap.htm
    Otherwise, you could extrude a sketch as a surface up to the curved surface and then use the split tool.  Those tools will get your sketch onto the curved surface.  But you can't extrude a 3D entity, so you should use move face or thicken.  That will get you this:
    Or, if your goal is just to have a cylinder poking out of the curved surface, sketch on another plane and then extrude up to face.  That will get you this:
